How to print this curved pipe?
Mavoz
(@mavoz)
Hi there,
I'm having difficult trying to print shapes like this that overhang. It gets to the half way point of the curve of these kind of shapes and fails.
What should I do? Thanks for any clues!
https://tinypic.host/i/pipeprusa.hAxj4
Questa discussione è stata modificata 3 years fa 2 tempo da Mavoz
Postato : 27/06/2022 1:38 am
Antonio
(@antonio)
Utenti Moderator
RE: How to print this curved pipe?
Yep,that's not very easy to print, or at least, it's not easy to get it printed well.
First thing first, did you enabled the supports, right?
then, have you tried to print it layed on the side?
I'm not an expert. Ma parlo anche italiano 😉
Postato : 27/06/2022 10:32 am
1 persone hanno apprezzato
Shouldn't be too hard to print with supports. With proper support settings they should come off nicely and not show too many pock marks.
Here's what I use most of the time:
Style: Snug
0.25mm z distance
3mm pattern spacing
4 interface layers
75% xy distance
0.2mm interface layer spacing
0mm first layer expansion
Postato : 27/06/2022 10:47 am
Interior supports on the pipe section will be problematic.  Personally I would place it 'elbow down' on to the build plate.  Such that both open ends point upwards at 45 degrees.  The I would paint on some support for the elbow on the outside, set to support for enforcers only, to give it a firm platform to start with.  The finished print would then have very little support required.
If you post your project or even a link to the model we can do an example for you.
Postato : 27/06/2022 12:29 pm
Just downloaded a similar model to use as an example.  2 minute job so can readily be optimised by spending more time, just to get the idea across.
Attached the project too so you can open it to see the paint on supports and settings.  Nothing special in it though, all basic simple stuff.
Postato : 27/06/2022 12:42 pm
towlerg
(@towlerg)
totally agree with Neophyl. you have to accept that the curved section touching the bed (unless you're clever than me) is gonna look horrible so make use of that fact and add a 2 or 3 mm thick solid oval. Something like the attachment, with or without the thinner mouse ear (trim that away when finished printing). I printed this in both ABS and ASA without additional support.
Questo post è stato modificato 3 years fa 2 tempo da towlerg
Postato : 27/06/2022 1:08 pm
Well If I was needing something similar I would model up the elbow to actually be flat on that joining corner.  That way there would be zero support needed and it would look a lot neater when its modelled in that way.
Postato : 27/06/2022 1:24 pm
Mavoz
(@mavoz)
Thanks all for the various suggestions...lots of great ideas. I ended up adding supports..and printing from the flat curve base of the pipe.
It added a far bit of raft junk..but I was then able to use a screw driver...and a grinder to tidy it up!
Thankfully it worked! The print from the elbow position would have been interesting too!
Anyway it got the job one..learned a lot about supports..I generally try to avoid them at all costs...but could see no other option with this one.
Thank you for all the suggestions!
Postato : 27/06/2022 1:35 pm
Mavoz
(@mavoz)
Posted by: @neophyl
Thanks for this idea....I haven't done a lot with supports..so is great to see how others approach it. Appreciate it!
Postato : 27/06/2022 1:38 pm
Everybody has their own preferences...
Joan
Postato : 27/06/2022 10:31 pm
jsw
 jsw
(@jsw)
I would most likely do it as Neo suggested.
I've had the best luck with tricky odd-shaped objects by getting them to fit as symmetrical as possible on the build plate.
I would also use soluble support material if the appearance is important, as the break-away support will certainly blemish the surface.
Postato : 27/06/2022 10:36 pm
Swiss_Cheese
(@swiss_cheese)
Just to throw my 2Cent's in I would have done it the way Joan did. I think it's cleaner.
To each their own.
Swiss_Cheese
The Filament Whisperer
Postato : 28/06/2022 3:24 am
towlerg
(@towlerg)
Not wishing to disagree with two stalwarts of the board but the problem with Joan's solution is that for most pipe fittings the mating section is most critical and that in this case provided the elbow is not so horrible the it leaks, then only  the open ends matter.
Postato : 28/06/2022 4:23 pm
