How to prevent Prusa Slicer from placing the raft below supports outside the print bed?
Matthias Nagel
(@matthias-nagel)
How do I prevent Prusa Slicer from placing the raft below supports outside the print bed?
I have a large object which nearly fills the entire print bed (minus 2mm on each side). I have some overhangs near the edge which require supports. If the support was only straight below the object everything would be fine, but Prusa Slicer creates a raft below the support structure which exceeds the limits of the print bed. This is true for any type of support. I had hoped that maybe organic structure could do the trick if they grew from the inside to the outer edge, but no, Prusa Slicer places them even slightly more outside.
Figure 1: The entire object: the problematic part is the overhang in the middle of the left edge
Figure 2: Organic supports: The raft exceeds the print bed
Figure 3: Grid supports: Same problem
Postato : 22/02/2026 11:19 am
Walter Layher
(@walter-layher)
RE: How to prevent Prusa Slicer from placing the raft below supports outside the print bed?
You could try decreasing the option marked in the following screenshot. Click on the image to see it without cropping.
Postato : 22/02/2026 12:41 pm
Geoff Steele
(@geoff-steele)
If that suggestion doesn't work out and you've created the object, perhaps add your own support as part of the model, keeping it inside the footprint?
Postato : 22/02/2026 1:16 pm
This has been an open issue since at least 2018.  Please see https://github.com/prusa3d/PrusaSlicer/issues/849 which has some potential workarounds.
Postato : 22/02/2026 1:55 pm
Matthias Nagel
(@matthias-nagel)
I found a solution:
  • Type: Snug
  • Pattern: Honeycomb
  • First layer expansion: 1mm
This does the trick.
Postato : 22/02/2026 9:46 pm
1 persone hanno apprezzato
