How to get ride of Nozzle Priming On Ender 3 V2?
Gingergamer425
(@gingergamer425)
Utenti
I am new to using Prusa Slicer and I would like to know how to get ride of the strip it does off to the ride of the build plate. With Prusa Slice it prints to strip off of the build plate so it either curls up to the nozzle to make the print fail or is just on the bottom of the printer. I would like to get ride of that and have the priming of the nozzle be where the Skirt is instead. Thanks 🙂
Questa discussione è stata modificata 2 years fa da Gingergamer425
Postato : 20/01/2024 4:20 pm
Berentis
(@berentis)
Utenti
RE: How to get ride of Nozzle Priming On Ender 3 V2?
The code that creates the priming strip is part of the printer settings. With Expert setting, you will see a section with "Start G-code".
There are two lines with the comment '; prime the nozzle'. These gcodes tell your printer to deposit the filament in two lines.
That being said, if the printer is trying to print off the build plate, you may have your print bed size wrong, or some other printer config in error.
I am a novice to 3d printers too, but my day job is in software. Hopefully this helps.
Postato : 18/03/2024 12:45 am
