How to get rid of solid infill
Page 2 / 2
Snuffleupagus
(@snuffleupagus)
That's part of it, but unfortunately you need to go farther to establish a working solution.
Swiss_Cheese Shown this early on. The Newer versions of slicer require more.
Keep moving forward.
This post was modified 2 years ago 3 times by Snuffleupagus
Posted : 22/08/2024 1:21 am
Chris Enders
(@chris-enders)
RE: How to get rid of solid infill
I had that exact problem, i wanted to print a vase with 3 perimeters not as vase mode and those solid infills were generated.
Modifier with no top and bottom layer fixed it for me. Thank you so much.
Posted : 31/08/2024 12:32 pm
Jonathan_Ott
(@jonathan_ott)
But if you need bottom layers, all is lost?
Posted : 10/10/2024 3:27 pm
No.  You use a modifier to set the 0 top and bottom, to the layers you want.  Either a modifier mesh or a layer modifier depending on your needs.
Posted : 10/10/2024 4:20 pm
Jonathan_Ott
(@jonathan_ott)
Posted by: @neophyl
Ahhhh! It took me a minute (not at my computer) but I think I understand. Gotta try that later.
Posted : 10/10/2024 8:49 pm
Jonathan_Ott
(@jonathan_ott)
Okay. I'm playing with it now and what I did was bring the original model onto the build plate and set it to 1 perimeter, 0 top layers, and 0 bottom layers; next I bring in a modifier OF THE SAME MODEL and it lays in exactly in the OG model, but then on that modifier, I click the edit gear, select the layer option and then set the bottom layer to 10 and the top layer to 5 and one perimeter and bingo, bango, Bob's your uncle it works. Now I have one perimeter, no "SOLID INFILL" where I don't want it (but some solid infill that I can live with) and it is actually a couple grams lighter than what the designer says it should weigh (even with 20% lightning infill to support the top layer).
What I don't want:
What I get now
What I want to get:
Posted : 11/10/2024 2:17 am
Silviu
(@silviu)
I'm not sure if this will help you or not, but in my case in SuperSlicer the setting which made the "magic" is the following: "Ensure vertical shell thickness", changed from "Enable 2.5" (same results like you guys) to "Partial 2.9 experimental " or "Disabled". In this way those "infills" are removed completely.
I'm not using |PrusaSlicer, but maybe it has something similar.
All the best!
Posted : 23/05/2025 10:40 am
Page 2 / 2
