How to get lost print settings back?
Teemu B.
(@teemu-b)
Hi, I had print settings connected to printer profiles by setting dependencies, but it seems as I renamed the printer profile, the print settings disappeared from the list and unfortunatelly I cannot see any of them anymore. I tryied to rename the printer profile back, but either I inserted not 100% correct name, or it doesnt connect back. How can I fix this? Or how can I see all the print settings profiles I have regardless of printer?
TIA
Postato : 29/08/2025 1:21 pm
RE: How to get lost print settings back?
you can try importing a config from a Gcode file, sliced in Prusa slicer
Postato : 29/08/2025 3:46 pm
1 persone hanno apprezzato
Teemu B.
(@teemu-b)
Unfortunately, I can only do that for few. No other way?
Postato : 29/08/2025 5:08 pm
Can you use  Configuration Snapshots, in the prusa slicer configuration drop down menu?
Postato : 29/08/2025 6:21 pm
Teemu B.
(@teemu-b)
I was lurking in config folder, just opened few of the ini files in hope I can read them and maybe use them for recovery and sudenly the lost settings are all back. I didnt change anything in the ini files. No idea what happened as from my point of view I did nothing to fix it, but it is solved for me now.
Postato : 02/09/2025 2:59 pm
Now you have them back take the opportunity to perform a Config Bundle export.  File>Export>Export Config bundle.  Either with or without physical printers.
That will back up to a file any CUSTOM profiles for Print, Filament and Printers.  It does not back up ones installed by the wizard but seeing as those can be reinstalled by the same config wizard thats not usually a problem.  You can then restore them to a new install on any computer at a later date.
Postato : 02/09/2025 4:38 pm
2 persone hanno apprezzato
Teemu B.
(@teemu-b)
I do that every time before PS upgrade, this was just different situation
Postato : 05/09/2025 3:02 pm
