How to fix walls
kkaroliss
(@kkaroliss)
How to fix walls
Hello, i marked problem in red. These are seen also in final print. How to fix this? Maybe there is some setting in Prusa slicer?
Opublikowany : 22/03/2022 11:33 pm
RE: How to fix walls
Looks like the z seam. You can't avoid it but you can adjust its position under Print Settings  (the magnifying glass icon is your friend if you're looking for a setting), or by using the paint-on seam tool.
Opublikowany : 23/03/2022 2:32 am
towlerg
(@towlerg)
I'm not sure thats seam, is it normally a different colour?
@kkaroliss What is the seam setting in Prusaslicer?  Print Settings/Layers and Perimeters/Seam position. Use help if you can't find it.
Opublikowany : 23/03/2022 11:11 am
kkaroliss
(@kkaroliss)
this is my settings for Seam
Opublikowany : 23/03/2022 10:24 pm
