RE: How to fix walls
Looks like the z seam. You can't avoid it but you can adjust its position under Print Settings (the magnifying glass icon is your friend if you're looking for a setting), or by using the paint-on seam tool.
Opublikowany : 23/03/2022 2:32 am
I'm not sure thats seam, is it normally a different colour?
@kkaroliss What is the seam setting in Prusaslicer? Print Settings/Layers and Perimeters/Seam position. Use help if you can't find it.
Opublikowany : 23/03/2022 11:11 am
Opublikowany : 23/03/2022 10:24 pm
