How to display time remaining on an Ender 5 series?
Dinierto
(@dinierto)
I have an Ender 5 and 5 Pro and neither one displays the time remaining when I print from GCODE sliced with Prusa Slicer.  However I know someone who does the same thing and has the time showing but they don't know what they did.  I've checked "supports remaining times" in Printer Settings but it didn't seem to help.
Best Answer by Neophyl:
The Prusa firmware on something like a MK3 uses the following is designed to use the following as an example-
M73 P0 R106
M73 Q0 S106
The R and S are the remaining times in normal and stealth modes I believe.  The Prusa printer firmware knows those values are remaining times and depending on the mode it is in displays that time.  The firmware is specifically set up to do that.
An M117 code is just a print to screen command so if Cura is adding those lines then that's why it will display from Cura generated code.
Napsal : 17/02/2021 4:51 pm
RE: How to display time remaining on an Ender 5 series?
The remaining times use a specific gcode which I don’t think the ender range supports in their firmware.
Napsal : 17/02/2021 5:56 pm
1 lidem se líbí
Dinierto
(@dinierto)
@neophyl
and yet I know someone who has it working... also, when using the time remaining plugin from Cura, it works.  I'm not sure what method Cura uses though.  So there's some way of doing it, I would love to find out how
Napsal : 17/02/2021 7:41 pm
Dinierto
(@dinierto)
@neophyl
Edit:  I looked at Gcode from Cura and it has the following line:
M117 Time Left 8h47m40s
I can't find a line in my Prusa-generated code that looks similar.  The only lines that don't have annotation are to turn off the fan and to set print percentage; what line does Prusa Slicer normally use?
Napsal : 17/02/2021 7:48 pm
If one of the users is running OctoPrint, it can insert time remaining messages during a print.
Napsal : 17/02/2021 9:03 pm
Posted by: @dinierto
You can output this with Prusa Slicer or S3D either via a message M117 per layer or via the function M73 per layer. However, the firmware must be able to implement this.
Napsal : 17/02/2021 9:40 pm
Dinierto
(@dinierto)
@karl-herbert
So there's no way to have Prusa automate an M117?  Because my firmware does seem to support it as shown by Cura.
Is M73 the code Prusa uses?  Because there is an M73 line.  So that must be the difference between the slicers
Napsal : 18/02/2021 2:28 am
M73 P0 R106
M73 Q0 S106
Napsal : 18/02/2021 8:18 am
1 lidem se líbí
Marlin_main.cpp:
case 73: //M73 show percent done and time remaining
if(code_seen('P')) print_percent_done_normal = code_value();
if(code_seen('R')) print_time_remaining_normal = code_value();
if(code_seen('Q')) print_percent_done_silent = code_value();
if(code_seen('S')) print_time_remaining_silent = code_value();
Napsal : 18/02/2021 9:46 am
Dinierto
(@dinierto)
@neophyl
Thank you that was very informative!  I'm doing more googling and research now.  There's a script for Prusa Slicer to convert but I can't get it to work, it throws back an error.
http://phoenix.yizimg.com/scheric/Prusaslicer-M73-to-M117-macro
I installed Python and copied the script to a directory, and pasted the links inside the quotes.  It gave me an error code 1, lol.
Napsal : 18/02/2021 2:54 pm
@dinierto
Both Bob and Karl could probably help you with your script issues, unfortunately I don’t use any so am not familiar with the in and outs. I’m in the same boat as you, ie looking it up on google lol.
Napsal : 18/02/2021 3:57 pm
@dinierto
I have just tested this on my W10 machine. Installed Python 3.8, added the following line to the PS output:
The following result (normal mode only):
Python 3.8 for Windows: https://www.python.org/downloads/release/python-385/
Napsal : 18/02/2021 4:38 pm
Dinierto
(@dinierto)
@karl-herbert
I did the same and got an error, I don't know what I'm doing wrong.  Here's the links I added to mine
Napsal : 20/02/2021 9:38 pm
@dinierto
What error exactly did you get? The files (python.exe and script.py) must be present in the appropriate path.
During the Python installation the environment path variable should be selected.
Napsal : 20/02/2021 10:15 pm
Dinierto
(@dinierto)
@karl-herbert
I believe it said Error 1.  And those files are exactly where those paths are, that's how I got the paths was by tracking down where Python installed to and copying the script to that directory.
I don't know what "the environment path variable" means though
Napsal : 21/02/2021 2:05 am
