How to delete profiles or clean uninstall Prusaslic3r in Mac
[Risolto] How to delete profiles or clean uninstall Prusaslic3r in Mac
Jansen
(@jansen-2)
Hi there,
I would like to do a clean uninstall of Prusaslicer and a total clean install again without all the previous profiles and configurations.
I move the whole folder from applications to trash and install again my profiles are still there.
please help me thanks 🙂
Best Answer by bobstro:
Posted by: @zoombee
Hi there,
Delete the app by dragging it to the trash normally. Delete the profiles under your /users/yourname/Library/Support Files/ folder for PrusaSlicer. You can also delete user profiles by checking the appropriate box in the PrusaSlicer configuration wizard.
Postato : 17/03/2020 9:48 am
RE: How to delete profiles or clean uninstall Prusaslic3r in Mac
Posted by: @zoombee
Hi there,
Postato : 17/03/2020 12:53 pm
Jansen
(@jansen-2)
@bobstro
Thank u so much
Postato : 17/03/2020 1:05 pm
kellywoods524
(@kellywoods524)
I have the latest stable release of PrusaSlicer installed on my MacBook Pro (Catalina) and I never use the Drag-to-trash method to uninstall an app. Because this quick fix has a significant drawback - all the application’s service files will be left behind on your Mac. These files will continue to consume storage space while the app was removed.
To remove PrusaSlicer or other bloated application completely, you need to remove its executable file and all the service files stored in ~/Library and /Library folders (as mentioned in this guide ).
Here is list of the most common folders that store PrusaSlicer orphans:
~Library > Application Support
~Library > Caches
~Library > Logs
~Library > Preferences
~Library > Containers
~Library > Cookies
Many thanks,
Clem
Postato : 23/03/2020 5:00 pm
