How to configure nozzle fan to start up slowly and not full blast on second layer?
bizilux
(@bizilux)
Hey all...
so ever since upgrading from mk3 to mk3s, I've been having problems where the temperature of the hotend dips quite a lot during second and third layers, occasionally triggering thermal runaway. Temperature should be 210, but its 190 for example... then after a few layers it goes back up, because i assume air is not blowing so hard on it and bouncing from the bed...
I have not really figured out how to adjust fan curve so that it starts slower and not at 100% on second layer
Napsal : 09/12/2019 4:21 pm
RE: How to configure nozzle fan to start up slowly and not full blast on second layer?
A silicone sock should help.
Napsal : 09/12/2019 5:07 pm
bizilux
(@bizilux)
Posted by: @bobstro
yeh i did see that suggestion before... but in the meantime i would like to fix it with hardware... and im just looking if its possible to not start the fan at 100% on layer two...
Napsal : 09/12/2019 5:10 pm
bizilux
(@bizilux)
okay, I ordered the silicone socks, so I suppose I will suck it up until then and just monitor and manually adjust temperatures at the start of each print...
Napsal : 09/12/2019 5:21 pm
You might check the fit  of your cooling fan duct to make sure it's pointed at the nozzle and not the heater block.
Napsal : 09/12/2019 5:52 pm
Doug
 Doug
(@doug-6)
@bobstro
A silicon sock does help, had the same problem, now variance is only a couple of degrees and only for a very short while.
Napsal : 14/12/2019 11:35 pm
