How to avoid support on hidden surface?
pirates
(@pirates)
Hello all,
recently started to use the prusa slicer and I have this question: How can I avoid supports on a surface that I cannot see?
However I turn and rotate this part, the bottom of the vertical hole is never completely visible. Is there a way to cut the part or to show only the lower half like what we do when we look into the different layers after slicing?
Edit: I want to print the part in this orientation.
Thanks and Best regards
This topic was modified před 2 years by pirates
Napsal : 21/07/2024 9:56 am
pirates
(@pirates)
RE: How to avoid support on hidden surface?
Solved 🙂
Napsal : 21/07/2024 11:12 am
