How to assign default extruder?
pop aruaru
(@pop-aruaru)
The default extruder for Slicer when using the MMU is number 1, but if anyone knows how to change this extruder number, please let me know.
For example
  •  if you want to assign an extruder other than number 1 to a collection of many objects, such as engraving letters,
  • When printing in a single color, I have sometimes printed with a material other than number 1 depending on the amount of filament remaining. If I could change the default, I could prevent making the wrong selection.
It is easier and more accurate to specify it by changing the default extruder number. When using the MMU, it is very time-consuming to switch filaments.
Best Answer by BaconFase:
Corycwagner is correct. When the object is set to "Default" extruder it pulls the extruder number from the Multiple Extruders settings page. The only reason it defaults to extruder 1 is because it is set to extruder 1 in the settings page by default.
So if you have multiple models in a project file all set to "Default" on the plater which uses extruder 1 for single color, but you want to change "Default" to extruder 5, then you just have to change the first three Multiple Extruder settings to 5.
Posted : 26/03/2025 4:16 am
corycwagner
(@corycwagner)
RE: How to assign default extruder?
In the Print Settings tab, go to "multiple extruders".  There are many defaults for extruders that you can set.
Posted : 26/03/2025 6:46 pm
pop aruaru
(@pop-aruaru)
Thanks.
But The advice is not what I need. I only need a way to define the default extruder number, not various default settings for the MMU.
If it's there, please let me know what it is.
This post was modified 4 months ago by pop aruaru
Posted : 27/03/2025 2:24 am
BaconFase
(@baconfase)
XL-5T, MK3S MMU3 || Printing with multiple nozzle-sizes: Official Guide, Unofficial || PrusaSlicer Fork || Other advanced slicer tactics || TPU
Posted : 27/03/2025 9:09 pm
pop aruaru
(@pop-aruaru)
Thanks
Posted : 28/03/2025 6:57 am
pop aruaru
(@pop-aruaru)
The color of the slicer is the same as extruder#1, but I think it should be a different color.
Posted : 29/03/2025 1:13 am
BaconFase
(@baconfase)
You'll need to zip up your 3mf project file and upload it here. I can't troubleshoot on zero information when I've already shown how it can be done.
Posted : 29/03/2025 4:47 am
pop aruaru
(@pop-aruaru)
I set the Multiple Extruders setting to #3, but the default color is the same as #1.
The color of the sliced ​​G-code is correct.
choose Default
Posted : 30/03/2025 3:18 am
BaconFase
(@baconfase)
I'm not aware of any way to uncouple that default color from extruder 1's color.
Posted : 30/03/2025 6:52 pm
pop aruaru
(@pop-aruaru)
It's hard to understand the changes, but I'm glad the problem was solved.
Thank you.
Posted : 31/03/2025 8:33 am
