How not to leave support marks
Hello, I'm new to the 3D world
I need help in the following problem. I can't adjust the support settings for this part,I've tried in many ways, and always the support grabs and leaves many marks.
Someone would have some config, so that I can print without these problems.
Attachment config.ini with config that I am using
Prusaslyce_config_bundle.ini with printer configs
piece.3mf Project with the piece to print
My printer is Ender 3 s1
I thank you for the helpsorry the English
config.ini
# generated by PrusaSlicer 2.6.0-alpha6+win64 on 2023-06-23 at 21:19:34 UTC autoemit_temperature_commands = 1 avoid_crossing_curled_overhangs = 0 avoid_crossing_perimeters = 0 avoid_crossing_perimeters_max_detour = 0 bed_custom_model = bed_custom_texture = bed_shape = 5x0,215x0,215x220,5x220 bed_temperature = 60 before_layer_gcode = ;BEFORE_LAYER_CHANGE\nG92 E0\n;{layer_z}\n\n between_objects_gcode = bottom_fill_pattern = monotonic bottom_solid_layers = 5 bottom_solid_min_thickness = 0 bridge_acceleration = 250 bridge_angle = 0 bridge_fan_speed = 100 bridge_flow_ratio = 0.85 bridge_speed = 60 brim_separation = 0 brim_type = outer_only brim_width = 0 color_change_gcode = M600 colorprint_heights = compatible_printers_condition_cummulative = "printer_model=~/(ENDER|CR|SERMOON).*/ and nozzle_diameter[0]==0.4";printer_notes=~/.*PRINTER_VENDOR_CREALITY.*/ complete_objects = 0 cooling = 1 cooling_tube_length = 5 cooling_tube_retraction = 91.5 default_acceleration = 500 default_filament_profile = "Generic PLA @CREALITY" default_print_profile = "0.16 mm OPTIMAL (0.4 mm nozzle) @CREALITY" deretract_speed = 30 disable_fan_first_layers = 3 dont_support_bridges = 0 draft_shield = disabled duplicate_distance = 6 elefant_foot_compensation = 0.1 enable_dynamic_fan_speeds = 0 enable_dynamic_overhang_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n" end_gcode = {if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+2, max_print_height)} F600 ; Move print head up{endif}\nG1 X5 Y{print_bed_max[1]*0.85} F{travel_speed*60} ; present print\n{if max_layer_z < max_print_height-10}G1 Z{z_offset+min(max_layer_z+70, max_print_height-10)} F600 ; Move print head further up{endif}\n{if max_layer_z < max_print_height*0.6}G1 Z{max_print_height*0.6} F600 ; Move print head further up{endif}\nM140 S0 ; turn off heatbed\nM104 S0 ; turn off temperature\nM107 ; turn off fan\nM84 X Y E ; disable motors external_perimeter_acceleration = 0 external_perimeter_extrusion_width = 0.42 external_perimeter_speed = 60 external_perimeters_first = 0 extra_loading_move = -2 extra_perimeters = 0 extra_perimeters_on_overhangs = 0 extruder_clearance_height = 25 extruder_clearance_radius = 55 extruder_colour = #FCE94F extruder_offset = 0x0 extrusion_axis = E extrusion_multiplier = 1 extrusion_width = 0.44 fan_always_on = 1 fan_below_layer_time = 100 filament_colour = #4388FC filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 120 filament_density = 1.24 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 15 filament_minimal_purge_on_wipe_tower = 15 filament_notes = "" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = 1.5 filament_retract_lift = 0.2 filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_speed = 50 filament_settings_id = "PLA 3D NACIONAL - COR AZUL" filament_soluble = 0 filament_spool_weight = 0.123 filament_toolchange_delay = 0 filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = Generic filament_wipe = nil fill_angle = 45 fill_density = 5% fill_pattern = gyroid first_layer_acceleration = 0 first_layer_acceleration_over_raft = 0 first_layer_bed_temperature = 60 first_layer_extrusion_width = 0.42 first_layer_height = 0.2 first_layer_speed = 20 first_layer_speed_over_raft = 30 first_layer_temperature = 210 full_fan_speed_layer = 0 fuzzy_skin = none fuzzy_skin_point_dist = 0.8 fuzzy_skin_thickness = 0.3 gap_fill_enabled = 1 gap_fill_speed = 20 gcode_comments = 0 gcode_flavor = marlin gcode_label_objects = 1 gcode_resolution = 0.0125 gcode_substitutions = high_current_on_filament_swap = 0 host_type = prusalink idle_temperature = nil infill_acceleration = 0 infill_anchor = 600% infill_anchor_max = 50 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.44 infill_first = 0 infill_overlap = 23% infill_speed = 80 inherits_cummulative = "0.16 mm OPTIMAL (0.4 mm nozzle) @CREALITY";"Generic PLA @CREALITY"; interface_shells = 0 ironing = 0 ironing_flowrate = 15% ironing_spacing = 0.1 ironing_speed = 15 ironing_type = top layer_gcode = ;AFTER_LAYER_CHANGE\n;{layer_z} layer_height = 0.2 machine_limits_usage = emit_to_gcode machine_max_acceleration_e = 5000 machine_max_acceleration_extruding = 500 machine_max_acceleration_retracting = 1000 machine_max_acceleration_travel = 500 machine_max_acceleration_x = 500 machine_max_acceleration_y = 500 machine_max_acceleration_z = 100 machine_max_feedrate_e = 60 machine_max_feedrate_x = 500 machine_max_feedrate_y = 500 machine_max_feedrate_z = 10 machine_max_jerk_e = 5 machine_max_jerk_x = 8 machine_max_jerk_y = 8 machine_max_jerk_z = 0.4 machine_min_extruding_rate = 0 machine_min_travel_rate = 0 max_fan_speed = 100 max_layer_height = 0.32 max_print_height = 270 max_print_speed = 100 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_bead_width = 85% min_fan_speed = 100 min_feature_size = 25% min_layer_height = 0.06 min_print_speed = 15 min_skirt_length = 4 mmu_segmented_region_max_width = 0 notes = nozzle_diameter = 0.4 only_retract_when_crossing_perimeters = 0 ooze_prevention = 0 output_filename_format = {input_filename_base}_{print_time}_{digits(layer_height,1,2)}mm_{temperature[0]}C_{filament_type[0]}_{printer_model}.gcode overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 overhang_speed_0 = 15 overhang_speed_1 = 15 overhang_speed_2 = 20 overhang_speed_3 = 25 overhangs = 0 parking_pos_retraction = 92 pause_print_gcode = M25 ; pause print perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0.44 perimeter_generator = arachne perimeter_speed = 60 perimeters = 3 physical_printer_settings_id = post_process = print_host = print_settings_id = 0.20 mm - Edutech - CASE - PONTE- MASTER 4 printer_model = ENDER3S1 printer_notes = Don't remove the following keywords! These keywords are used in the "compatible printer" condition of the print and filament profiles to link the particular print and filament profiles to this printer profile.\nPRINTER_VENDOR_CREALITY\nPRINTER_MODEL_ENDER3S1\nPRINTER_HAS_ULTRADETAIL printer_settings_id = Creality Ender-3 S1 (0.4 mm nozzle) printer_technology = FFF printer_variant = 0.4 printer_vendor = printhost_apikey = printhost_cafile = raft_contact_distance = 0.1 raft_expansion = 1.5 raft_first_layer_density = 90% raft_first_layer_expansion = 0 raft_layers = 0 remaining_times = 0 resolution = 0 retract_before_travel = 1 retract_before_wipe = 0% retract_layer_change = 1 retract_length = 0.8 retract_length_toolchange = 1 retract_lift = 0 retract_lift_above = 0.2 retract_lift_below = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 30 seam_position = rear silent_mode = 0 single_extruder_multi_material = 0 single_extruder_multi_material_priming = 0 skirt_distance = 1 skirt_height = 2 skirts = 1 slice_closing_radius = 0.049 slicing_mode = regular slowdown_below_layer_time = 20 small_perimeter_speed = 20 solid_infill_acceleration = 0 solid_infill_below_area = 0 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0.44 solid_infill_speed = 60 spiral_vase = 0 staggered_inner_seams = 0 standby_temperature_delta = -5 start_filament_gcode = "; Filament gcode\n" start_gcode = G90 ; use absolute coordinates\nM83 ; extruder relative mode\nM104 S150 ; set temporary nozzle temp to prevent oozing during homing\nM140 S{first_layer_bed_temperature[0]} ; set final bed temp\nG4 S30 ; allow partial nozzle warmup\nG28 ; home all axis and restore leveling\nG1 Z50 F240\nG1 X2.0 Y10 F3000\nM104 S{first_layer_temperature[0]} ; set final nozzle temp\nM190 S{first_layer_bed_temperature[0]} ; wait for bed temp to stabilize\nM109 S{first_layer_temperature[0]} ; wait for nozzle temp to stabilize\nG1 Z0.28 F240\nG92 E0\nG1 X2.0 Y140 E10 F1500 ; prime the nozzle\nG1 X2.3 Y140 F5000\nG92 E0\nG1 X2.3 Y10 E10 F1200 ; prime the nozzle\nG92 E0 support_material = 1 support_material_angle = 0 support_material_auto = 0 support_material_bottom_contact_distance = 0 support_material_bottom_interface_layers = -1 support_material_buildplate_only = 0 support_material_closing_radius = 2 support_material_contact_distance = 0.3 support_material_enforce_layers = 0 support_material_extruder = 0 support_material_extrusion_width = 0.22 support_material_interface_contact_loops = 0 support_material_interface_extruder = 0 support_material_interface_layers = 2 support_material_interface_pattern = auto support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = rectilinear-grid support_material_spacing = 2.5 support_material_speed = 60 support_material_style = grid support_material_synchronize_layers = 0 support_material_threshold = 0 support_material_with_sheath = 0 support_material_xy_spacing = 80% support_tree_angle = 40 support_tree_angle_slow = 25 support_tree_branch_diameter = 2 support_tree_branch_diameter_angle = 5 support_tree_branch_distance = 1 support_tree_tip_diameter = 0.8 support_tree_top_rate = 15% temperature = 205 template_custom_gcode = thick_bridges = 0 thin_walls = 0 threads = 4 thumbnails = thumbnails_format = PNG toolchange_gcode = top_fill_pattern = monotonic top_infill_extrusion_width = 0.4 top_solid_infill_acceleration = 0 top_solid_infill_speed = 60 top_solid_layers = 7 top_solid_min_thickness = 0 travel_acceleration = 0 travel_speed = 150 travel_speed_z = 0 use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 variable_layer_height = 1 wall_distribution_count = 1 wall_transition_angle = 10 wall_transition_filter_deviation = 25% wall_transition_length = 100% wipe = 1 wipe_into_infill = 0 wipe_into_objects = 0 wipe_tower = 0 wipe_tower_bridging = 10 wipe_tower_brim_width = 2 wipe_tower_cone_angle = 0 wipe_tower_extra_spacing = 100% wipe_tower_no_sparse_layers = 0 wipe_tower_rotation_angle = 0 wipe_tower_width = 60 wipe_tower_x = 170 wipe_tower_y = 140 wiping_volumes_extruders = 70,70 wiping_volumes_matrix = 0 xy_size_compensation = 0 z_offset = 0
Veröffentlicht : 23/06/2023 10:41 pm
