How is the current state of “no sparse layers?”
Plastic Golem
(@plastic-golem)
Hi everyone.
I was having issues of diagonal stringing appearing at the end of my MMU prints, going from the wipe tower to the printed parts.
I have narrowed it down to the setting “no sparse layers (experimental)” and searching this, can not find too many specific posts about this, and the last one I found was a year ago.
From watching the print, I’ve noticed it will wipe, then travel upwards in Z before making the X+Y moves to the part.
During the vertical move, it will ooze. This then stretches across to the part and falls onto it, giving the illusion it is from a diagonal move.
In the long run, this causes issues with blobbing as it will end up on the sock and nozzle, sometimes accumulating on infill, etc.
Is there any setting I can use to set retraction solely for the travel distance from the wipe tower to the part?
Thank you in advance to everyone.
Best Answer by Neophyl:
Correct, there is no setting for that.  Hence you cant find any information on it.
Postato : 08/08/2025 6:22 am
Dry your filament and keep it dry (dryboxes) during long prints.
Postato : 08/08/2025 9:32 am
Plastic Golem
(@plastic-golem)
RE: How is the current state of “no sparse layers?”
Thank you - I’ve already dried the PETG and it is run through a closed heater system and buffer.
The stringing only occurs during the vertical Z move from the wipe tower, so I have isolated the issue to the no sparse layers setting.
I cannot find any information about setting retraction settings solely for this 1-2 seconds of movement, so I am assuming it was never implemented.
I will avoid using this setting when printing PETG.
Postato : 08/08/2025 10:12 am
Postato : 08/08/2025 1:03 pm
1 persone hanno apprezzato
