How can I remove these shifts when a horizontal hole finishes?
Chungnun
(@chungnun)
as you can see in the image, I have these small shifts above holes. This sometimes happens in the opposite direction, and is usually only on that specific wall or direction, not across the whole print at those layers. What can I do to fix it?
Respondido : 22/05/2022 8:48 pm
Swiss_Cheese
(@swiss_cheese)
RE: How can I remove these shifts when a horizontal hole finishes?
@chungnun
Based purely on the image you shown, I'm guessing that your part warped a bit (Lifted from the bed) in that corner before it completed.
If that's the case my advice is for you to look at ways to stop warping, for example, an enclosure, Make sure your build surface is very clean, Use a suitable for printing after market adhesive, and adjust your temps & cooling in a way that helps eliminate warping, etc,,.
Good Luck
Swiss_Cheese
Esta publicación ha sido modificada el hace 4 years por Swiss_Cheese
The Filament Whisperer
Respondido : 23/05/2022 12:46 am
Chungnun
(@chungnun)
Hello, I checked and that corner is not lifted. I think it has to do possibly with layer times, as it stops happening right as the hole is bridged
Respondido : 23/05/2022 8:53 pm
