How can I make an item solid infill
jdenver
(@jdenver)
I have created an enclosure in FreeCAD 0.21.2 but when slicing the 4 smaller parts of the posts (2.9mm diameter) in the bottom of the enclosure are not solid, they are printing as hollow with the tops closed off, as a result they are not very strong. How can I make these into a solid post?
Ive attached the file I'm using in PrusaSlicer 2.8.0
Thank you
Napsal : 25/08/2024 5:44 pm
You can increase infill to 100% under Print Settings>Infill. However, you'll get more strength by increasing the number of perimeters instead. Print Settings>Layers and Perimeters>Vertical shell. Try 5. This will also give you more perimeters in the base but who cares. Or if you care, use a height range modifier to change perimeters from 1.8mm upward. See attached 3mf file.
Napsal : 25/08/2024 6:23 pm
1 lidem se líbí
jdenver
(@jdenver)
RE: How can I make an item solid infill
Thank you so much for the three different options and the .3mf file, it all helps me to understand PrusaSlicer a little better.
Napsal : 26/08/2024 9:12 am
You can also set the Print Settings>Infill>Advanced>Solid Infill Threshold Area to something like 7 (for this model)  and that will fill any area with a surface area less than 7mm squared with solid infill while allowing larger areas to remain unchanged.  Its a red setting so you need to be in Expert mode to see it.
Napsal : 26/08/2024 11:53 am
1 lidem se líbí
jdenver
(@jdenver)
I like that idea. Thanks
Napsal : 27/08/2024 9:43 am
