Hotend Temp error when slicing for Creality CR-10
mjsteve
(@mjsteve)
With the upgrade to 2.5.0 I've noticed that when I slice an .stl for my Creality CR10, the hotend temp is set at 150 vs the normal 215 for PLA.  Anyone else notice this?  It's not a printer issue as Cura still works fine.
Postato : 16/09/2022 9:15 pm
RE: Hotend Temp error when slicing for Creality CR-10
I dont have that printer installed but check to see if the profile for the printer has been updated in the start gcode section.  Its quite common to heat the nozzle to a 'no ooze' temp before doing things like levelling and once its done that then the extruder heats up to full temp.  Its the way it is on the mini and a lot of us use the same technique for the mk3.
Basically its done to let thermal expansion happen and it stops little dots of filament on your bed when its probing.
If you save a project file from within PS (File>save project as) and then take the produced 3mf file and zip it up and attach it here we can take a look at all the settings you are using and have a much better chance of debugging things.  Must be zipped for the forum to accept the file.
Postato : 16/09/2022 9:25 pm
mjsteve
(@mjsteve)
Thank you!  It was the 'no ooze' pre-heat, I must not have noticed that pause in temp before.  I appreciate the help.
Postato : 17/09/2022 12:28 am
