Honeycomb Infill for Top Layer(s)
redchairlabs
(@redchairlabs)
I was wondering if there was a way to use the honeycomb infill pattern as a top layer for a print. I want to texturize the surface finish of a flat, horizontal surface for a better grip. Is there a way to set this up in PSlicer?
Respondido : 17/12/2025 2:41 pm
Sembazuru
(@sembazuru)
RE: Honeycomb Infill for Top Layer(s)
Interesting question, and I have one answer for you. There may be other techniques.
I applied a height-range modifier to the top of a cube. I arbitrarily chose 2 layers. To this modifier I set the number of top layers to 0 and the infill to honeycomb. I also added 2 layers to the default top layers for the full object to get the default number of top layers under the honeycomb texture. Here is the project for my experiment and a screenshot of the sliced result.
TopHexTexture
There may be other ways to do this, but this was my first thought.
See my (limited) designs on:
Respondido : 18/12/2025 5:05 am
redchairlabs
(@redchairlabs)
This seems to track with what I was thinking. Thank you for testing the solution for me. I will give it a try later today.
Respondido : 18/12/2025 4:24 pm
