Helper Disk Not Working As Intended
Amir Khan
(@amir-khan)
Prusa Slicer 2.8.1
I followed all steps in this video:
Could not do anything about "clip multi part objects" option because it is not present in 2.8.1. But the Prusa documentation says that it is always on internally so no worries there.
Problem: The overlapping area prints for both the original model and the helper disk. That's not the effect I am expecting to see. Are there any other settings I can change to achieve desired effect? (that is, original model and helper disk are joined but still print their own areas cleanly separated by a perimeter)
I made sure that the helper disk was added by selecting and then right clicking the original model. Them being "joined together" was further verified by clicking and dragging the original model, and it moved the helper disk with it. Perimeters settings also changed to 99.
What else? Thanks.
Opublikowany : 01/11/2024 3:48 pm
