Help with output file naming
FanDeZyii
(@fandezyii)
Hello!
Please is it possible to find out how are named the variable of the umber of instances - I want the file name to include how many models im printing (I usually make gcodes with 2, 4, 8 instances of a single model / group of models and print them depending on how much time I have).
Also is there a complete list the variables that can be used?
Thank you!
Napsal : 21/10/2024 4:28 pm
Sembazuru
(@sembazuru)
RE: Help with output file naming
Try using "num_instances" in your output filename format and see if that works for you. I haven't experimented with this, myself, so please report back if this works.
How I found this (FYI if you need to look up other placeholder names): The help text for output filename format states that you can use all configuration options as variables. So I went to the custom g-code editor (click the edit icon on one of the custom g-code text boxes) and found under "Objects info" a placeholder "num_instances" that has the description "Total number of object instances in the print, summed over all objects".
See my (limited) designs on:
Napsal : 21/10/2024 5:02 pm
2 lidem se líbí
_KaszpiR_
(@_kaszpir_)
https://help.prusa3d.com/article/list-of-placeholders_205643 num_instances is there
Napsal : 22/10/2024 7:47 am
