help! print is splotchy and weird!
I’ve got a Prusa MK3 S that’s keeps printing like this on the first layer. I did one print right before this with the same filament, same temperatures and same height so I don’t know why it seems to stop pulling the filament through at that exact point every time
Ce sujet a été modifié il y a 2 years par Bennie Orrett
Publié : 30/01/2024 11:11 pm
Two possibilities: Most likely you have a partial clog -- have you switched from a higher temperature filament to a lower recently?
Or: You have a build-up of dust in your Bondtech gears, I use a stiff artist's brush to clean them.
Publié : 31/01/2024 1:40 am
