Help me please !!!
Cyril
(@cyril)
Miembro
Help me please !!!
Bonjour à tous !
Voilà mon problème, je viens d'arriver il y a peu de temps sur prusaslicer. Je lance mon print où il y a 3 tours avec un mode lissage mais cela fait 2 fois sur 2 ou la buse vers la fin du print rentre en contact avec le print car elle descend volontairement dessus alors qu'elle ne devrait pas et du coup le casse !!! Auriez-vous une idée svp ? ?
Respondido : 11/10/2023 4:57 am
DJ
 DJ
(@dj-3)
RE: Help me please !!!
You may have overlooked this but..
..it would help if you added a descriptive title and placed the message in the French forum? (or translate your message to English?)
Respondido : 11/10/2023 1:35 pm
We would need much more information than you have given us.  Firstly we need your prusa slicer project file.  Set up PS to slice just like it gives you the problem and then use File>Save Project As.  This will save a 3mf file.  The 3mf file will contain not just the model but also all of the settings you are using.  With it we can slice the gcode just like you do.  To attach a 3mf file though you MUST first zip it into an archive to attach to the forum.
The forum only allows a very limited number of file types.  We a project we can check if there's any incorrect settings. etc.
Secondly we need to know what printer and firmware version you are using.
And to reiterate DJ's point, this is the English forum, I had to use google translate for your post.  Google is great but the translation leaves a lot to be desired, Im not sure we can understand your entire issue from your description.  Hence the request for the 3mf file.
Respondido : 11/10/2023 1:46 pm
