Help for Newbie - Filament Profiles
Brian
(@brian-14)
I just purchased a I3S with MMU and some filament.  I am trying to learn how to use PrusaSlicer2.1.0 but cannot figure out how to import or create a filament profile for Flexfill 98A.  All help greatly appreciated.
Opublikowany : 27/10/2019 9:04 pm
RE: Help for Newbie - Filament Profiles
Modify the Generic PLA profile to fit your needs, then click the save icon (floppy disk next to the name): name it appropriately and it'll be available to load whenever you need it again.
Opublikowany : 28/10/2019 7:41 am
Brian
(@brian-14)
Thanks for the advice.  I had already experimented with doing just that but not knowing enough about filaments, I'm sure that what I've done is not optimal.  Surely there is a library of preconfigured settings for each filament?
Related to that, I watched a video about PrusaSlicer 2.0.  When the demonstrator opened up the filament tab (top right on the Plater tab) there appeared to be dozens of filaments from many different suppliers.  When I open that tab on my installed software, there only 11 preset configurations.  Did I fail to install something in the set up process?
Opublikowany : 28/10/2019 4:28 pm
