Help!
I'm new to prusaslicer and for some reason all my presets were deleted and now when i try to print it starts to move as soon as i start the print! it doesn't wait to heat the nozzle up or the bed (The bed doesn't heat up at all!) Can someone help me get it to wait to heat up before starting! Thanks 🙂
RE: Help!
Remove the app and reinstall it.
RE: Help!
ok i will try that
RE: Help!
it started working but the bed won't heat up. I have the settings for 65 degree bed on a Ender 3 Pro. It says the heat goal is 0 degrees and the temp is 0 degrees.
RE: Help!
RE: Help!
Go to Printer Settings and click the drop down list for selecting the printer preset. At the bottom, there is "Add/Remove Printers". Go through that wizard again to select Creality, then Ender 3. It'll add your system presets back.
