Has Custom G-Code been removed?
Hello,
I am attempting to build an ABS Temperature Tower. I created one in the past and added custom g-code. From what I read it should be under the Printer Settings tab. I also saw some references to custom g-code being incompatible with the 2.0 PrusaSlicer. Has it been removed? Do I need to edit the g-code manually? I searched through all the tabs and searched for the answer.
Thank you for your assistance,
Willie
Willie Peloquin
N8WP Eschew obfuscation, espouse elucidation.
Publié : 27/10/2019 6:08 pm
RE: Has Custom G-Code been removed?
You just need to activate expert mode to get access to these settings.
Publié : 27/10/2019 6:44 pm
Topic starter
answered:
Thank you so much
Willie
Willie Peloquin
Publié : 28/10/2019 4:46 am
