GUI Colors / Unreadable text on MacOS
StephanB
(@stephanb-2)
I just installed PrusaSlicer 2.81 on MacOS Sonoma 14.6.1 and the GUI text is unreadable.
In the configuration assistant, text appears black on dark gray and in the app, the text is white on light gray.
If I switch to Dark Mode, in the MacOS settings, it, windows background becomes black, so text is readable, but I don't usually use dark mode. I know that PrusaSlicer follows the Light/Dark system settings on MacOS, but I can't find where I can change text/window color to something readable.
Thanks,
Stephan
I tried to reinstall, deleting all settings, doesnt help.
Any idea?
Is there a way to change text/window background color to something readable?Prusa Config
Prusa Settings
This topic was modified 2 years temu by StephanB
Opublikowany : 17/10/2024 12:19 pm
2 ludzie polubili
3dpicnic
(@3dpicnic)
RE: GUI Colors / Unreadable text on MacOS
Same problem here with macOS 14.7. Very hard to do the setup this way.
Opublikowany : 02/11/2024 4:54 pm
MaslovyRohlik
(@maslovyrohlik)
same with 15.2. white text on light gey background..horrible
Opublikowany : 21/12/2024 10:05 pm
HenrikLager
(@henriklager)
Have the same problem but it started suddenly and has not been corrected with 2.9.0 so I thought it might be some setting on my Mac that is faulty.
Opublikowany : 13/01/2025 9:41 am
HenrikLager
(@henriklager)
I switched to "dark mode" as someone suggested and that seems to be the only "fix".
Not a huge thing on an other awesome software but a little bit annoying.
Opublikowany : 15/01/2025 3:03 pm
1 ludzie polubili
