gpu ram
madman
(@madman-2)
Mitglied
gpu ram
I recently went from P slicer 2.5 to 2.9 and large more complicated objects take a while to slice but the real problem is trying to move the sliced model or look at the layers.The lag is so great etc.pretty much unusable.I have read others having the same issue.Could it be I don't have enough gpu ram?
Veröffentlicht : 31/03/2025 8:34 pm
3Delight
(@3delight)
Moderator Moderator
RE: gpu ram
You'll need to post your system specs (CPU, RAM, GPU, VRAM) for anyone to be able to help!
Veröffentlicht : 31/03/2025 10:08 pm
TomasCremin
(@tomascremin)
Mitglied
RE: gpu ram
Adjust your rendering settings to reduce GPU load by going to Preferences > Rendering, reducing the model detail level or turning off VBOs (Vertex Buffer Objects) if enabled.
fall guys
Veröffentlicht : 02/04/2025 1:15 am
FrankNStl
(@franknstl)
Mitglied
RE: gpu ram
Posted by: @tomascremin
cany ou share a screenshot? i dont see the rendering options on latest prusaslicer
Veröffentlicht : 27/11/2025 11:21 am
John vanDiggelen
(@john-vandiggelen)
Mitglied
RE: gpu ram
I have the same issue. BabuLab does not have this problem.
Version: 2.9.4
Build: PrusaSlicer-2.9.4
Operating System: WindowsSystem Architecture: 64 bitWindows
Version: Windows 11 (build 22631),
64-bit edition
Total RAM size [MB]: 16,512MB
HP Elitebook
i5 VPRO
16Gb memory
1T SSD
Posted by: @madman-2
Veröffentlicht : 04/12/2025 9:12 am
