gpu ram
madman
(@madman-2)
gpu ram
I recently went from P slicer 2.5 to 2.9 and large more complicated objects take a while to slice but the real problem is trying to move the sliced model or look at the layers.The lag is so great etc.pretty much unusable.I have read others having the same issue.Could it be I don't have enough gpu ram?
Napsal : 31/03/2025 8:34 pm
3Delight
(@3delight)
Moderátor Moderator
RE: gpu ram
You'll need to post your system specs (CPU, RAM, GPU, VRAM) for anyone to be able to help!
Napsal : 31/03/2025 10:08 pm
TomasCremin
(@tomascremin)
RE: gpu ram
Adjust your rendering settings to reduce GPU load by going to Preferences > Rendering, reducing the model detail level or turning off VBOs (Vertex Buffer Objects) if enabled.
fall guys
Napsal : 02/04/2025 1:15 am
