Getting wobbly perimeter lines
Ninju
(@ninju)
Hello PrusaSlicer folks,
Using PrusaSlicer (2.9.4) with a Prusa XL 5TH (6.2.6+8948)
Getting strange wobbly lines on the perimeter of my box print (it is a Fusion 360 model exported as STL and add to PS project)
To see if its an issue with printer hardware (tensioning, head alignment, etc...) I recreated a version of the object using PrusaSlicer primitives (just a Box part with a negative volume in the middle) and it printed fine
Any ideas?
(I can provide the .3mf file if need be)
Posted : 02/02/2026 10:22 pm
jan.d.slay
(@jan-d-slay)
RE: Getting wobbly perimeter lines
The solution is almost in the question.
Please export the “problem part” in STEP format and try again.I suspect you chose a “poor resolution” when creating the STL.
Posted : 04/02/2026 8:34 am
Ninju
(@ninju)
Hello!
Posted by: @jan-d-slay
When you say 'choose poor resolution when creating the STL" what do you mean?
I used Fusion360 to create design and used the File:Export menu option
I don't see any way to adjust the resolution
So is STEP format a better export format to use all the time?
This post was modified 3 months ago by Ninju
Posted : 07/02/2026 2:38 am
jan.d.slay
(@jan-d-slay)
I just realized that I wanted to add something. I didn't mean exporting directly from the CAD component via this menu from your screenshot, but rather by right-clicking on the relevant object in Fusion360.
The option is called "Create mesh," and then you can adjust the resolution in the settings.
That's what I meant.
Posted : 07/02/2026 8:06 am
