Getting "File Incomplete" errors when using PrusaSlicer with a particular configuration
Aaron Pigeon
(@aaron-pigeon)
I'm about a week into my Prusa journey, and starting to dig into some calibration processes to learn the ropes. I am trying to follow the steps here to address stringing issues: https://projects.ttlexceeded.com/3dprinting_techniques_calibrating_retraction.html
It took me the better part of a day, but I was able to figure out how to set up the virtual multi-extruder profile. However everything that I slice using this profile now generates the "File Incomplete" error when starting the print from the SD card. Have checked the following things:
  • Confirmed that I can slice and print other files from the default profile without this issue.
  • Confirmed that the sliced file contains "; prusaslicer_config = end" as the last line.
  • Manually added "MK3S" to the gcode printer model check.
  • Painstakingly checked every single config field in the profile comparison tool to make sure the new Printer Profile I created had the same settings as the defaults (the profile management experience is horrid for a first timer!).
I can just click through and print anyway, but it would be nice to know what's causing this issue and if there are perhaps other problems here that I haven't discovered yet. It's not obvious how to attach gcode or config files here, but I can add a Dropbox link if that would help.
Thanks in advance!
Postato : 21/01/2023 2:44 am
Aaron Pigeon
(@aaron-pigeon)
RE: Getting "File Incomplete" errors when using PrusaSlicer with a particular configuration
Looks like I can zip and attach the gcode that here:
completeObjects_MultiStringTest_0.15mm_PLA_MK3S_39m.gcode
Postato : 21/01/2023 4:58 pm
What are the stringing issues?
Postato : 21/01/2023 5:43 pm
Aaron Pigeon
(@aaron-pigeon)
My post describing the issues and steps I've taken so far is pending approval. Here's a very short summary of where I'm at: https://imgur.com/gallery/Low0cDN
Postato : 21/01/2023 6:17 pm
Reset defaults and dry your filament.
Postato : 22/01/2023 2:50 am
1 persone hanno apprezzato
Aaron Pigeon
(@aaron-pigeon)
How can you tell it's wet? It seems unlikely given it prints basically everything else just fine with the default settings.
Postato : 22/01/2023 3:24 am
You are printing a torture test designed to promote stringing.   In addition to the expected strings there are typical wet-filament strings.
Postato : 22/01/2023 1:07 pm
Robin
(@robin)
Posted by: @diem
That's good advice. You should do both.
Postato : 22/01/2023 4:32 pm
