Generic PLA Silk profile is compatible with what printers? MK4?
NR
 NR
(@nr)
After updating my configuration, I no longer have access to the "Generic PLA Silk" profile.  In the wizard, this profile is marked with an asterisk saying it is not compatible with some installed printers.
The only printer I have is a MK4.  On older versions of the software, I used the Generic PLA Silk profile with no issues.  Is it now supposed to be incompatible with the MK4?  I'm a relative noob and am not sure what profile I should be using now
Publié : 16/04/2024 5:08 pm
IG
 IG
(@ig)
RE: Generic PLA Silk profile is compatible with what printers? MK4?
I am using PrusaSlicer 2.7.4 and MK4 I see Generic PLA Silk on all profiles (normal, IS, and MMU3). Perhaps you are using a 0.6 nozzle? (see message in PrusaSlicer below)
Filaments marked with * are not compatible with some installed printers. (for me, this is my MINI+)
This is what I see on the configuration wizard > filaments tab (bottom) when I select Generic PLA Silk"
"Only the following installed printers are compatible with the selected filaments:
  • Original Prusa MK4 MMU3 0.4 nozzle
  • Original Prusa MK4 Input Shaper 0.4 nozzle"
X marks the spot.
Publié : 20/04/2024 2:58 am
