GCODE preview not available
Jiří Fiala
(@jiri-fiala)
PS 2.6.0 on Mac. Pressing C (as per documentation) to display Gcode of the sliced model is doing nothing. Other shortcuts such as L for Legend do work.
How do I preview the actual gcode other than downloading and viewing in a text editor?
Opublikowany : 10/08/2023 7:40 am
RE: GCODE preview not available
Yeah its a bit screwy at the moment.  After slicing and it goes to the preview of the sliced file the L key works to show/hide the legend.  The C key doesnt for the gcode.
Scroll the bottom slider a bit to get to the part of the object where you want to examine the gcode for and then click in the main preview window.  Then click the C key.  That should then bring up the gcode list on the left .  As you scroll the bottom slider the gcode preview window will update to show that section.  If thebottom scroll bar is all the way to the right the gcode preview goes away.
Opublikowany : 10/08/2023 12:16 pm
TupacIlmond
(@tupacilmond)
The GCODE preview issue may require you to scroll the bottom slider, then click C to view GCODE. It's a workaround.
Opublikowany : 03/11/2023 5:59 am
