Gcode layer images
Jd Lancaster
(@jd-lancaster-2)
Utenti
Gcode layer images
Is it possible to extract images of each gcode layer?  I want to make a sort of flipbook kind of like an MRI scan I think?  I am wondering if this is possible in Prusa slicer, or if there is an external software/script I could run to get this.
Postato : 26/01/2024 7:43 pm
RE: Gcode layer images
If you slice for a Prusa Mini,
I Believe the output file is a zip format file, with images of the individual layers enclosed
Postato : 27/01/2024 9:53 am
_KaszpiR_
(@_kaszpir_)
You need to add SLS printer to the PrusaSlicer and use it as a printer, adjust layers etc, then slice and export and rename exported file as .zip and you can extract images.
Also see https://github.com/nvtkaszpir/3d-print/blob/main/stl-to-png/README.md
And https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/help-needed-for-project-using-slicer/
Postato : 27/01/2024 2:55 pm
1 persone hanno apprezzato
Arndt Großmann
(@arndt-grosmann)
Utenti
When I do this, the images have grey pixels in them. Is that correct? Wouldn't that just produce regions with half-polymerized resin? Or did I configure it incorrectly?
Postato : 28/10/2024 3:40 pm
JamesMitchell
(@jamesmitchell)
Utenti
Very interesting! You can try using PrusaSlicer to export each G-code layer. Otherwise, there are some external scripts like G-code Viewer that can help you extract the image of each layer. Good luck with your flipbook project!
Success is not the key to happiness. Happiness is the key to success. - "Basket Random"
Postato : 06/01/2025 3:47 pm
Sembazuru
(@sembazuru)
After you have sliced an object you can then export the toolpath as an OBJ file. I don't know what workflow would be required afterword to get your desired result. But, there is the possibility of a path...
See my (limited) designs on:
Postato : 06/01/2025 10:40 pm
