Gaps in perimeter
Otter Arms
(@otter-arms)
Gaps in perimeter
What setting is causing these gaps in the perimeter and how do I change it? I am actually getting tiny gaps in my print. I have tried retraction settings, thinking it was that, but they are still there even after turning off retraction and wipe.
Gaps
Publié : 04/10/2019 4:30 pm
RE: Gaps in perimeter
Hi Pipcorona,
Are you sure the gaps are at the  start and finish of the layers?
try a cylindrical test piece with the seam position set to 'Aligned'  (in the 'Print Settings >Layers and Perimeters' menu, at the bottom
and this will cause a seam like this
if the gaps are now aligned then you have proven that the issue is at the start finish seam area
I couldn't find a way to eradicate the gaps, without going to Spiral Vase Mode...   but on maximum magnification this seemed to show a massive number of tiny cracks , which don't seem to materialise when printing.
Publié : 05/10/2019 12:34 am
Otter Arms
(@otter-arms)
@joantabb
I am able to confirm that by watching the print. It leaves a visible gap in the print too which weakens the print.
Publié : 05/10/2019 1:04 am
See if changing any of these helps.
ps: sorry about image sizes, but this damn forum sucks now that they've change image sizing properties.
Ce message a été modifié il y a 7 years 3 fois par --
Publié : 05/10/2019 5:17 am
Oh, and are you using an MMU?  What is the K factor you are using?
Publié : 05/10/2019 5:31 am
Otter Arms
(@otter-arms)
@tim-m30
I tried getting rid of the gap closing radius and it is still there. I am not using an MMU. Forgive my ignorance, but what is the K factor?
Publié : 09/10/2019 9:25 pm
Part of the custom gcode; k-factor changes the start-stop flow characteristics.  If wrong, it can cause gaps and oddities at seams.
Are you concerned about the gap shown in P.Slicer? Or are your parts having gaps?  A photo of an affected part will be more helpful.
Publié : 09/10/2019 9:44 pm
Otter Arms
(@otter-arms)
@tim-m30
For my PLA it is
M900 K{if printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}200{elsif nozzle_diameter[0]==0.6}18{else}30{endif} ; Filament gcode
And PETG is
M900 K{if printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}200{elsif nozzle_diameter[0]==0.6}24{else}45{endif} ; Filament gcode
Ce message a été modifié il y a 7 years par Otter Arms
Publié : 10/10/2019 1:46 am
Still need an image of the part that has the problem.  Once we see the actual problem, maybe we can help.
Publié : 10/10/2019 4:07 am
Steve123
(@steve123)
I am experiencing this problem as well.
Publié : 29/01/2020 8:09 pm
Steve123
(@steve123)
I tried changing the closing radius to 0mm and it made no difference.  I tried 0.2mm and the problem was worse.
Publié : 29/01/2020 8:14 pm
Steve123
(@steve123)
The STL file was generated from FreeCAD.
Publié : 29/01/2020 8:15 pm
Petr Jezek
(@petr-jezek)
I'm having the issue with perimeter gaps as well. It makes them in the same layer and it's visible a lot on the actual print.
Publié : 22/04/2020 11:24 am
Area51
(@area51)
Membre
@steven-s23
The parameter Slice gap closing radius is used to correct small gaps/errors in STL files before slicing. It has no effect on the printed perimeter gaps.
The small defects in perimeter is created when the extruder starts/stops extrusion. Depending on the used filament, K value, temperature and retraction the defects can be minimized. I normally set the seam position to aligned or rear to move the defects to a non important position on the model.
Publié : 22/04/2020 11:42 pm
