Gap fill does fill only half of model
[Gelöst] Gap fill does fill only half of model
Toby
 Toby
(@toby-3)
Hi
I am printing the Honeycomb storage wall (wall-honeycomb-part.stl) and my first layer shows some gaps in some of the combs. Looking at the slicer output, I see that only some combs are gap-filled.
Zooming out, the gap fills are in about half the model only. What is the reason for this? Is there another way to make sure the bottom layer is nice and smooth?
Some settings:
  • Layer + First Layer height: 0.25
  • Perimeters: 4
  • Infill: 0
  • Fill Gaps: yes
  • Perimeter generation: Classic
Thanks.
Best Answer by JoanTabb:
Hi Toby,
Use a Height Range Modifier, to create a small zone of the model to have different parameters, so if you make the height range modifier active from 0mm to 0.2mm  and set the perimeters to 1 you will achieve this  setup.
if you wish, you can make the modifier  thicker and make more layers single perimeter... or whatever settings that you wish to change
Modifiers can start at any level, and be any thickness you want.
Jess  Zipped .3mf file
the image below, shows that one perimeter leaves more space for infill, giving a pleasing effect
in the image below, there are two perimeters on the letters and that messes up the infill as you can see
this is a similar issue to your Hex outlines where there is insufficient space for infill
I hope these files help you see how the bottom  layer and the top two layers were set for one perimeter
whilst the rest of the layers have more perimeters
Veröffentlicht : 14/02/2024 1:20 pm
RE: Gap fill does fill only half of model
Try adjusting extrusion width. Or try one perimeter for the first layer to leave space for solid infill
Veröffentlicht : 14/02/2024 1:54 pm
Maybe you want to upload your 3mf project file? That way we can see your settings. I don't see any of this slicing the file with standard print profiles and adjusted for what you mentioned before.
Veröffentlicht : 14/02/2024 5:03 pm
Toby
 Toby
(@toby-3)
Posted by: @joantabb
I adjusted extrusion width and that worked quite well already, thanks! I'd like to try your second suggestion too, but I can't find where to adjust perimeters for only the first layer.
Veröffentlicht : 15/02/2024 8:31 pm
Toby
 Toby
(@toby-3)
I tried attaching the .3mf but I couldn't figure out how to do it. It allows me to upload images, but no .3mf.
Veröffentlicht : 15/02/2024 8:35 pm
miroslav.h4
(@miroslav-h4)
The *.3mf file must be packed in *.zip file, otherwise the forum will not accept it!
Veröffentlicht : 15/02/2024 9:29 pm
Hi Toby,
Veröffentlicht : 15/02/2024 9:59 pm
Toby
 Toby
(@toby-3)
Thanks for taking the time to write such an extensive answer! I finally got around to try this, and it improved my print quite a bit, but didn't make it perfect. But what I learnt from your post will help me many times n the future.
In the end, I printed the whole thing upside down and enabled ironing, which gave me the best result. I am happy how 🙂
Veröffentlicht : 04/03/2024 7:12 pm
