G29 shrink the print
jp
 jp
(@jp-2)
I have some troubles with PrusaSlicer 2.2.0 and G29 auto bed leveling on my Ender 5 printer with a BLTouch.
If I add G29 after G28 for auto bed leveling then the print is shrunk on Z axis (X and Y are OK).
Without the G29, the print is OK.
mde
Any idea what is going on?
Thanks
My gcode is:
; generated by PrusaSlicer 2.2.0+win64 on 2020-06-28 at 21:52:27 UTC
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; support material extrusion width = 0.40mm
; first layer extrusion width = 0.70mm
M73 P0 R32
M73 Q0 S30
M201 X1000 Y1000 Z1000 E5000 ; sets maximum accelerations, mm/sec^2
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm/sec
M204 P1250 R1250 T1250 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X5.00 Y5.00 Z0.40 E1.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
M140 S60 ; set bed temp
M190 S60 ; wait for bed temp
M104 S210 ; set extruder temp
M109 S210 ; wait for extruder temp
M300 S500 P500 ; chirp
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G29
Publié : 03/07/2020 4:16 pm
RE: G29 shrink the print
I don’t think this is a slicer problem. The gcode for the movement and extrusion is the same with or without so it’s not the output gcode at issue. It’s how your firmware is dealing with the G29 code. Normally a G29 would have some form of parameter, iirc there’s about 3 or 4 different ways it’s used. It may be that your firmware needs something besides the base code.
It could be the probing as setting some z micro stepping which is not reset when it comes to printing the actual gcode. What machine and firmware are you using ?  Can you contact the help/support of whoever supplied the firmware to ask ?
Publié : 03/07/2020 6:57 pm
