Fuzzy skin on top layer
eski
 eski
(@eski)
Is it possible to have fuzzy skin on top layers? The only way i found is to have the model a bit on angle but then i need supports.
Veröffentlicht : 29/07/2022 11:39 pm
Swiss_Cheese
(@swiss_cheese)
@eski
I have no idea what that represents relative to your model , but. No! you can not have fuzzy skin on the top of your model, unless you are willing to write and work with non-planer G-code.
So unless you are advanced/Expert with G-code the answer is NO. However if you are an expert, the answer is YES!
Regards
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 30/07/2022 12:25 am
jsw
 jsw
(@jsw)
RE: Fuzzy skin on top layer
I've done a similar thing, drafting a brickface texture and combining it with the model to let the brick texture be printed on the top side of the piece.
If you look at the model below, those bricks were printed with the brick textured side upward on the build plate.
You could make a 'fuzzy' texture instead of brick and combine it with your model using your favorite 3d drafting/editing program.
Veröffentlicht : 30/07/2022 6:10 am
Wetdesign
(@wetdesign)
If randomness is not important, you could use height Range modifier. Set solid top layers to 0, and use an infill pattern that matches your requirement. That way you could have stars, honeycombs and many more visible.
Veröffentlicht : 25/01/2024 11:12 pm
atloveday
(@atloveday)
Mitglied
Just use the paint on fuzzy skin option as per this https://help.prusa3d.com/article/fuzzy-skin_246186
Veröffentlicht : 28/11/2025 12:56 pm
Sembazuru
(@sembazuru)
Posted by: @atloveday
I would be surprised if this worked as AFAIK fuzzy skin is only along the X and Y axes, not affecting the Z axis.
See my (limited) designs on:
Veröffentlicht : 30/11/2025 7:35 am
