Fuzzy Skin going crazy at radius
I'm playing around with the fuzzy skin and I think there's a massive bug at radii.
The flat surface is as expected but at the 3mm and 1.5mm radius it's going crazy. It even produces overhangs by the fuzzy skin with a thickness of 0.2mm, distance 1.2mm and 0.2mm layers. I played around with the values, it's always more or less the same. The same on MK3s, MK4 with or without IS.
Any ideas what I might doing wrong?
Best regards,
Norbert
Napsal : 13/09/2023 9:42 pm
