Fusion360 model to PrusaSlicer
InfoBot vl. Boris Ignjatović
(@infobot-vl-boris-ignjatovic)
i need help i'm new to 3d print and i made my first box and cover model and when trying to print, print breaks down i send a test file attached so i ask someone for suggestions on how to avoid this. Thank youpoklopac_prusa.stl
Best Answer by bobstro:
That is because it is not flat on the bed. Those sections are caused by the "stairs stepping" effect on the uneven surface. Lay the part flat and it will slice as one solid surface. Also be aware that this STL will not print well until you lay it flat since the slant reduces bed adhesion.
Veröffentlicht : 04/09/2019 7:20 am
RE: Fusion360 model to PrusaSlicer
Your STL is slightly rotated. Use the Place on face button on the left side of the screen to select the bottom surface to make it lay flat. Once you do that, it will slice normally:
Veröffentlicht : 04/09/2019 7:32 am
Ok thanks this help but, one more thing how to avoid this section the surface is not solid you see that is in 12 sections if you understand me.
It can see on Preview mode when preview layers that it is in section not whole layer itself.
Veröffentlicht : 04/09/2019 7:38 am
Veröffentlicht : 04/09/2019 7:58 am
But I use now place on face and now is flat on bed and this is image after this step
Veröffentlicht : 04/09/2019 8:03 am
I will try this setup later today and send update to this thread.
Veröffentlicht : 04/09/2019 11:18 am
problem is the same pictures of first 5 layers in attachment, please help me how to resolve this.
I think that is problem in layers not in same height or something
omething
Diese r Beitrag wurde geändert Vor 7 years von InfoBot vl. Boris Ignjatović
Veröffentlicht : 04/09/2019 6:18 pm
Nikolai
(@nikolai)
Hello Boris,
bobstro provided already the reason and solution for your issue. Please try to follow the steps and see why your model in your slicer is not flat on the bed.
In addition I would check the original file in Fusion. You must have made some mistake during rotation. Usually if you create a model on a plane it stays perpendicular to all planes and you don't need to rotate it at all.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 04/09/2019 10:35 pm
Agreed - Bob provided the answer: it simply needs to be placed on the bed level.
Diese r Beitrag wurde geändert Vor 7 years von --
Veröffentlicht : 05/09/2019 5:29 am
Thanks guys I'am so stupid didn't realize that left side is not on table and that when use buton to stick to table need to click on some surface to stick ;).
Veröffentlicht : 05/09/2019 11:16 am
Nikolai
(@nikolai)
No worries. I'm glad it's working now for you, too.
Often linked posts:
Real Multi Material
Veröffentlicht : 05/09/2019 4:46 pm
