Fusion 360 to Prusa Slicer
Hey there everyone! I have an interesting issue that I am trying to pinpoint the root cause. I use F360 to mock up all of my ideas, then I will take the bodies and export them to my MK3s+ [F360-file-3d print (3mf)] and view the result in prusa slicer. When the files are viewed as a 3mf each items is exploded why outside of the margins they were in under f360. Also of note and a troubleshooting step, when I export and save my f360 file as an stl, everything looks great in prusa slicer yet I need the multiple bodies. Has anyone had a similar issue?
RE: Fusion 360 to Prusa Slicer
What happens when you export and import as .OBJ ?
The Filament Whisperer
I will try your method out! I have been fiddling with this for so long now, something I did worked! I dont know what I did (its been 6+hrs) yet it looks good. Now the harder part is doing it again
