FLSUN Q5: Printer profile available
DoctorRudd
(@doctorrudd)
Hello 🙂
Does some has a printer profile for the FLSUN Q5?
Thank you very much, Peter
Best regards, Peter
Postato : 22/09/2020 4:38 pm
Utenti
RE: FLSUN Q5: Printer profile available
I have not seen one but would ask here:
https://www.facebook.com/groups/120961628750040/
Postato : 26/09/2020 1:19 pm
DoctorRudd hanno apprezzato
Shane Finn
(@shane-finn)
Cannot actually upload the file itself (?!) so here is the contents of what I use:
# generated by PrusaSlicer 2.2.0+win64 on 2020-09-27 at 06:22:28 UTC
avoid_crossing_perimeters = 1
bed_custom_model =
bed_custom_texture =
bed_shape = 99.6195x8.71557,98.4808x17.3648,96.5926x25.8819,93.9693x34.202,90.6308x42.2618,86.6025x50,81.9152x57.3576,76.6044x64.2788,70.7107x70.7107,64.2788x76.6044,57.3576x81.9152,50x86.6025,42.2618x90.6308,34.202x93.9693,25.8819x96.5926,17.3648x98.4808,8.71557x99.6195,6.12323e-15x100,-8.71557x99.6195,-17.3648x98.4808,-25.8819x96.5926,-34.202x93.9693,-42.2618x90.6308,-50x86.6025,-57.3576x81.9152,-64.2788x76.6044,-70.7107x70.7107,-76.6044x64.2788,-81.9152x57.3576,-86.6025x50,-90.6308x42.2618,-93.9693x34.202,-96.5926x25.8819,-98.4808x17.3648,-99.6195x8.71557,-100x1.22465e-14,-99.6195x-8.71557,-98.4808x-17.3648,-96.5926x-25.8819,-93.9693x-34.202,-90.6308x-42.2618,-86.6025x-50,-81.9152x-57.3576,-76.6044x-64.2788,-70.7107x-70.7107,-64.2788x-76.6044,-57.3576x-81.9152,-50x-86.6025,-42.2618x-90.6308,-34.202x-93.9693,-25.8819x-96.5926,-17.3648x-98.4808,-8.71557x-99.6195,-1.83697e-14x-100,8.71557x-99.6195,17.3648x-98.4808,25.8819x-96.5926,34.202x-93.9693,42.2618x-90.6308,50x-86.6025,57.3576x-81.9152,64.2788x-76.6044,70.7107x-70.7107,76.6044x-64.2788,81.9152x-57.3576,86.6025x-50,90.6308x-42.2618,93.9693x-34.202,96.5926x-25.8819,98.4808x-17.3648,99.6195x-8.71557,100x-2.44929e-14
bed_temperature = 60
before_layer_gcode = ;LAYER:[layer_num]
between_objects_gcode =
bottom_fill_pattern = rectilinear
bottom_solid_layers = 3
bottom_solid_min_thickness = 0.4
bridge_acceleration = 0
bridge_angle = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 100
brim_width = 0
clip_multipart_objects = 1
colorprint_heights =
complete_objects = 0
cooling = 1
cooling_tube_length = 5
cooling_tube_retraction = 91.5
default_acceleration = 0
default_filament_profile = ""
default_print_profile =
deretract_speed = 0
disable_fan_first_layers = 3
dont_support_bridges = 1
draft_shield = 0
duplicate_distance = 6
elefant_foot_compensation = 0.2
end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
end_gcode = ; Printer end code\nM400 ;wait for moves to finish\nM104 S0 ;extruder heater off\nM140 S0 ;bed heater off\nG91 ;relative positioning\nG1 E-5 F500 ;retract the filament to release ooze pressure\nG90 ;absolute positioning\nG28 ; home all axes\nM84; disable motors\n
ensure_vertical_shell_thickness = 1
external_perimeter_extrusion_width = 0
external_perimeter_speed = 50%
external_perimeters_first = 0
extra_loading_move = -2
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_colour = #400040
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 1
fan_below_layer_time = 60
filament_colour = #29B2B2
filament_cooling_final_speed = 3.4
filament_cooling_initial_speed = 2.2
filament_cooling_moves = 4
filament_cost = 29
filament_density = 1.25
filament_deretract_speed = nil
filament_diameter = 1.75
filament_load_time = 0
filament_loading_speed = 28
filament_loading_speed_start = 3
filament_max_volumetric_speed = 5
filament_minimal_purge_on_wipe_tower = 15
filament_notes = "Magigoo: 225/65C => 215/60C\nGluestick: 225/65C => 215/30C @ 0% cooling"
filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
filament_retract_before_travel = nil
filament_retract_before_wipe = nil
filament_retract_layer_change = nil
filament_retract_length = nil
filament_retract_lift = nil
filament_retract_lift_above = nil
filament_retract_lift_below = nil
filament_retract_restart_extra = nil
filament_retract_speed = nil
filament_settings_id = "eSun PLA+"
filament_soluble = 0
filament_toolchange_delay = 0
filament_type = PLA
filament_unload_time = 0
filament_unloading_speed = 90
filament_unloading_speed_start = 100
filament_vendor = (Unknown)
filament_wipe = nil
fill_angle = 45
fill_density = 20%
fill_pattern = stars
first_layer_acceleration = 0
first_layer_bed_temperature = 65
first_layer_extrusion_width = 0
first_layer_height = 0.35
first_layer_speed = 50%
first_layer_temperature = 225
gap_fill_speed = 50
gcode_comments = 1
gcode_flavor = marlin
gcode_label_objects = 1
high_current_on_filament_swap = 0
host_type = octoprint
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 25%
infill_speed = 100
interface_shells = 0
layer_gcode =
layer_height = 0.2
machine_max_acceleration_e = 10000,5000
machine_max_acceleration_extruding = 1500,1250
machine_max_acceleration_retracting = 1500,1250
machine_max_acceleration_x = 9000,1000
machine_max_acceleration_y = 9000,1000
machine_max_acceleration_z = 500,200
machine_max_feedrate_e = 120,120
machine_max_feedrate_x = 500,200
machine_max_feedrate_y = 500,200
machine_max_feedrate_z = 12,12
machine_max_jerk_e = 2.5,2.5
machine_max_jerk_x = 10,10
machine_max_jerk_y = 10,10
machine_max_jerk_z = 0.2,0.4
machine_min_extruding_rate = 0,0
machine_min_travel_rate = 0,0
max_fan_speed = 100
max_layer_height = 0.36
max_print_height = 190
max_print_speed = 100
min_fan_speed = 100
min_layer_height = 0.08
min_print_speed = 10
min_skirt_length = 0
notes =
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
parking_pos_retraction = 92
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_speed = 100
perimeters = 2
post_process =
print_host = 192.168.2.9:8200
print_settings_id = PLA 0.2mm
printer_model =
printer_notes = Bed set @ 60c = 52C thermocouple = 58C infrared\nExtruder set @ 215C = 215C thermocouple
printer_settings_id = FLSUN Q5 0.4mm
printer_technology = FFF
printer_variant =
printer_vendor =
printhost_apikey = 643613BF3497431BBE6300040DFBB775
printhost_cafile =
raft_layers = 0
remaining_times = 0
resolution = 0
retract_before_travel = 2
retract_before_wipe = 0%
retract_layer_change = 0
retract_length = 6
retract_length_toolchange = 10
retract_lift = 0.25
retract_lift_above = 0
retract_lift_below = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 20
seam_position = random
serial_port =
serial_speed = 250000
silent_mode = 0
single_extruder_multi_material = 0
single_extruder_multi_material_priming = 1
skirt_distance = 10
skirt_height = 1
skirts = 2
slice_closing_radius = 0.049
slowdown_below_layer_time = 5
small_perimeter_speed = 25%
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0
solid_infill_speed = 50%
spiral_vase = 0
standby_temperature_delta = -5
start_filament_gcode = "; Filament gcode\n"
start_gcode = ; Printer start code\nG28 ; home all axes\nG1 X-90 Y-54 ; move extruder dribble off bed centre\n
support_material = 0
support_material_angle = 0
support_material_auto = 1
support_material_buildplate_only = 0
support_material_contact_distance = 0.3
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_contact_loops = 0
support_material_interface_extruder = 1
support_material_interface_layers = 1
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 100
support_material_synchronize_layers = 0
support_material_threshold = 0
support_material_with_sheath = 1
support_material_xy_spacing = 100%
temperature = 215
thin_walls = 1
threads = 8
thumbnails =
toolchange_gcode =
top_fill_pattern = rectilinear
top_infill_extrusion_width = 0
top_solid_infill_speed = 50%
top_solid_layers = 4
top_solid_min_thickness = 0.4
travel_speed = 1000
use_firmware_retraction = 0
use_relative_e_distances = 1
use_volumetric_e = 0
variable_layer_height = 1
wipe = 1
wipe_into_infill = 0
wipe_into_objects = 0
wipe_tower = 0
wipe_tower_bridging = 10
wipe_tower_no_sparse_layers = 0
wipe_tower_rotation_angle = 0
wipe_tower_width = 60
wipe_tower_x = 180
wipe_tower_y = 140
wiping_volumes_extruders = 70,70
wiping_volumes_matrix = 0
xy_size_compensation = 0
z_offset = 0
Postato : 27/09/2020 6:28 am
DoctorRudd e hanno apprezzato
You have to zip files into an archive to attach them.
Postato : 27/09/2020 9:52 am
Shane Finn
(@shane-finn)
Cool - thank you. That knowledge is probably in a FAQ somewhere I'd forgotten.
Postato : 27/09/2020 10:25 am
DoctorRudd
(@doctorrudd)
Thank you, I will give it a try 🙂
Best regards, Peter
Postato : 27/09/2020 12:31 pm
Meltchi
(@meltchi)
Posted by: @doctorrudd
Hello 🙂
I have successfully dialed in the Q5 and QQS-Pro on prusa slicer
Postato : 01/02/2021 3:00 pm
Meltchi
(@meltchi)
Postato : 01/02/2021 3:02 pm
Engineer Alex
(@engineer-alex)
@meltchi
Hey! Would you please upload the slicer profile for the Q5? I would really appreciate it.
Postato : 26/02/2021 7:55 pm
Meltchi
(@meltchi)
@engineer-alex
I have to boot up this afternoon and i will gladly share. It was a long 7hr process. To get it perfect. I can swmd the test stl file also so you can work on your 1st layer height
Postato : 26/02/2021 9:22 pm
pnobrega
(@pnobrega)
Did you ended up sharing?
Posted by: @meltchi
@engineer-alex
Postato : 16/11/2022 6:47 pm
