Flow Confusion
Ken
 Ken
(@ken-7)
Flow Confusion
I'm trying TPE filament for the first time.  From what I have read, flow should be set to about 115%.  I'm using the "FLEX' filament setting as my starting point.
In PrusaSlicer 2.7.0, I see:
Filament Settings > Filament -> Extrusion Multiplier = 1.15
This seems to match up with what I expected.
However, when printing, I looked at the i3 MK3 display window which is showing:
Tune -> Flow -> 95
Shouldn't this be showing 115?  Or am I misreading something?
Best Answer by Neophyl:
On the prusa profiles is a part of a printer start gcode block.  Printer Settings>Custom Gcode>Start Gcode.  You have to be in expert mode to see that section.
You will see a line something like M221 S{if layer_height<0.075}100{else}95{endif}
Posted : 02/12/2023 8:38 pm
RE: Flow Confusion
Those are different things, they both affect the amount of filament but are applied at different points. So extrusion multiplier is then multiplied by the flow.
so EM =1 as flow 95 then its 95%
EM =120 x flow of 95 is 114%
Posted : 02/12/2023 9:27 pm
Ken
 Ken
(@ken-7)
RE: Flow Confusion
So where is the "Flow" specified?
Posted : 02/12/2023 10:31 pm
RE: Flow Confusion
Posted : 03/12/2023 12:06 am
Ken
 Ken
(@ken-7)
RE: Flow Confusion
Got it.  Thanks much for the info.
Posted : 03/12/2023 4:46 pm
