Flexible Name of the gcode file
Wilko_SLO
(@wilko_slo)
It would be nice to have in the gcode file name:
Sample:
12pcs_ext4_Name of the print_0.2mm_ASA_MK3SMMU2S_5h15m.gcode
12pcs - how many instances does print include
ext4 - which extruder of MMU2S is used
It would be the best to have option in prusa slicer to chose what is included in name of the print file.
If I need multiple instances i prepare files with different number of items, depend on how much time I have to print.
Problem I noticed in the name:
If I use only ext4  and it is PLA in the print name it gives ASA, because EXT1 is selected ASA material.
W
Veröffentlicht : 31/12/2020 12:31 pm
Area51
(@area51)
Mitglied
RE: Flexible Name of the gcode file
I often print with multiple parts on a project and it is easy to change the filename when exporting. I prefer to add the count as x10 for 10 items or x8 for 8 items.
The problem with MMU2-Single and extruder material is reported on GitHub as an issue #5300 here.
Veröffentlicht : 01/01/2021 2:39 am
