First support layer on build plate
Tygan
(@tygan)
is it possible to change the first support layer on the buildplate?
I have problems to remove the thin lines from the smooth plate after printing PETG.
It would be great if I could change the first layer to one surface so it could be removed in one go.
Napsal : 03/10/2020 9:37 am
RE: First support layer on build plate
I do not know the answer to this question, but this is why my plates get a spray of Windex when print PETG.
Napsal : 03/10/2020 10:30 am
Not with the current versions of Prusa slicer no, its always there.  Super Slicer (which is a compatible fork of PS) you can set them to be 'solid' first layer
https://github.com/supermerill/SuperSlicer/releases
Napsal : 03/10/2020 10:36 am
Tygan se líbí
Tygan
(@tygan)
@neophyl
Perfect, thank you for the Super Slicer recommendation!
Napsal : 03/10/2020 11:05 am
