find original nozzle size
polo5959
(@polo5959)
I'm looking into old print I did (2 years ago) that I would like to reprint, but I can find the info on what nozzle size I was using. It was either a 0.4 or a 0.2mm
is there a way to find the info someware on the gcode file?
Publié : 17/11/2024 5:28 pm
If you have an ASCII g-code file search for a line beginning:
; nozzle_diameter =
And the value should be listed there.
Publié : 17/11/2024 5:57 pm
RE: find original nozzle size
Even easier than that, from Prusa Slicer select File>Import and then select your old gcode file.  Most of the settings are stored at the end of the file and PS will load them in from the file.  SO you can check many other things the gcode used like extrusion widths etc too.
Publié : 17/11/2024 6:52 pm
