Filling objects which consist multiple closed objects merged together? No fill is generated with default options?
hsu
 hsu
(@hsu)
I have a model which consists of multiple closed spaces - is there a way to tell prusaslicer to fill closed areas, but leave internal structures in place, so that I can use weak infill such as low-% fills or lightning to fill the model, to avoid long bridges to be used for horizontal surfaces? Critical stuff is supported with manually done structures.
https://www.suonsivu.net/3d-models/stevensonshield-base.stl
openscd model: https://www.suonsivu.net/3d-models/stevensonshield.scad
Makefile: https://www.suonsivu.net/3d-models/Makefile.stevensonshield
(if forceinfill in the start of file is enabled, a rudimentary support is manually done to support flat top.
cutout image of the whole model, the stl above is the base part where I would like to have light infill as it has large flat horizontal areas:
Napsal : 26/09/2024 5:12 pm
