File refuses to print
Pagina 1 / 2
Billzilla
(@billzilla)
I've been trying to print a small part a few times today and the printer just stops & goes into cooldown just as it's about to do the first layer for the part. A few days back I was able to print the part with no problems, and (AFAIK) nothing has changed. I tested a different parts 3MF and that worked fine. Any ideas please?
Postato : 25/04/2023 4:25 am
Hello
(@hello)
RE: File refuses to print
can you please show video
Postato : 25/04/2023 4:48 am
Hello
(@hello)
so i see alot wrong and missing in the gcode any chance i can get 3mf file your missing the stage where it waits for the temprature and goes through the checks
Postato : 25/04/2023 4:51 am
Billzilla
(@billzilla)
There isn't any video sorry. All that happens is the extruder starts to do the three loops around the parts (got five on the bed, spaced well apart for cooling time) and it just stops after a few seconds. I look at the Klipper browser page and it's gone into cooldown mode. That's all that happens.
Postato : 25/04/2023 4:52 am
Hello
(@hello)
1682396743-leaky-valve-3C
thats a gcode that shuld work from https://www.printables.com/model/61346-i3-mk3s-to-mk3s-upgrade-printable-parts/files i have yused it before
Postato : 25/04/2023 4:54 am
Billzilla
(@billzilla)
Here's the 3MF file. I align it so the top of the cap in on the bed and it has a 5mm brim around it to help it stay stuck. There's a bunch of errors that PS has to deal with, so I used the repair function on it before slicing.
Postato : 25/04/2023 4:56 am
Billzilla
(@billzilla)
Posted by: @hello
Okay I've got that gcode file and will try it soon, thanks.
I have no idea what that other link is for though sorry.
Postato : 25/04/2023 4:59 am
Hello
(@hello)
I can see in the gcode file what wrong please print first layer of gcode I sent you so I can confirm I'm right the I will help fix prusa slicer gcode output
Postato : 25/04/2023 5:00 am
Hello
(@hello)
The other link doesn't matter
Postato : 25/04/2023 5:01 am
Billzilla
(@billzilla)
Posted by: @hello
I'm sorry I'm not understanding what you want there. I looked at the previous gcode and it looks the same as that latest one you posted.
Postato : 25/04/2023 5:04 am
Hello
(@hello)
Oh um the file I added there was the original one posted by u then underneath there is a different one with different name
Postato : 25/04/2023 5:06 am
Hello
(@hello)
Do you see the other file the one with different name
Postato : 25/04/2023 5:10 am
Billzilla
(@billzilla)
Posted by: @hello
Yes, and I downloaded it. It seems to be exactly the same file but with a slightly different name.
Postato : 25/04/2023 5:26 am
Hello
(@hello)
Try print it what is the file called I may of acedintally upload wrong file
Postato : 25/04/2023 5:34 am
Billzilla
(@billzilla)
Posted by: @hello
It's the same file, I doubt anything different will happen.
Postato : 25/04/2023 5:37 am
Hello
(@hello)
It should be called y axis upgrade or something
Postato : 25/04/2023 5:41 am
Hello
(@hello)
If not let me know and I will repost new file
Postato : 25/04/2023 5:42 am
Billzilla
(@billzilla)
You've only re-posted the file that I attached. It doesn't work and I'm trying to find out why.
Postato : 25/04/2023 5:48 am
Hello
(@hello)
Yes I'm sorry I must of accedentally posted the same file I will repost right file
Postato : 25/04/2023 5:54 am
Hello
(@hello)
So the zip file I posted is the same but when download there are 2 files in it the one that says y axis ... Is the right one you need to try
Postato : 25/04/2023 5:56 am
Pagina 1 / 2
