file name appendages
In the 2.1.0 version of the slicer it appends a set of additional information about the print:
resolution
filament type
printer model
time
Can these additions be controlled? Not seeing anything the the "Preferences..." to toggle them.
RE: file name appendages
You can configure this under Print Settings->Output options->Output file->Output filename format.
I often store gcode files for re-use weeks or months later, so include a lot of detail in the filename using:
[input_filename_base] [notes] [filament_type] [layer_height]X[nozzle_diameter] [first_layer_temperature]-[temperature] [first_layer_bed_temperature]-[bed_temperature] [print_time].gcode
Thanks, it looks like one also need to change to "Advanced" mode to see this option.
can you add like filament used?
Yes
whats the variable name for filament used?
found it
Output filename format FDM
The macro language can be used in Output filename format field available in Print Settings -> Output options. In this context you can use all the configuration placeholders plus the following:
dayextruded_volumefilament_presethourinitial_extruderinitial_filament_typeinitial_toolinput_filenameinput_filename_baseminutemonthnormal_print_timenum_extrudersnum_instancesnum_objectsnum_printing_extrudersphysical_printer_presetprint_presetprint_timeprinter_presetprinting_filament_typesscalesecondsilent_print_timetimestamptotal_costtotal_toolchangestotal_weighttotal_wipe_tower_costtotal_wipe_tower_filamentused_filamentversionyear
Please try using the Prusa Slicer knowledge base, that's what its there for - https://help.prusa3d.com/article/list-of-placeholders_205643
For example I have "PS_[input_filename_base]_[print_settings_id]_{filament_settings_id[0]}.gcode" Print Settings /Output Options. This generate a file name with a bunch of parameters separated by underscores, a reminder that it was sliced with Prusaslicer, the original STL files name, the print profile, the filament profile.
