Filament profiles for different physical printers using same printer profile?
mikeymakesit
(@mikeymakesit)
Hi, I have 2 MK3S+ printers and each has a differently calibrated extrusion multiplier.  I'd like to have filament profiles saved for each physical printer, which only show up when the matching printer has been selected, but it seems that in the filament "compatible printers condition" I can only match on properties from the printer presets, not on "print_host" from the physical printer properties.  Am I overthinking this or making some mistake?
One workaround that works ok but requires redundant configuration is adding a printer preset for each physical printer then adding notes to those presets indicating the printer's name, then using that additional note in the filament profile condition.
Opublikowany : 10/06/2022 6:09 am
