Filament preset change with M600 (using 2 or more existing filament presets)
Royals
(@royals)
If I'm printing a part with a PLA preset (eSun, for example) and want to finish the last ten layers with a different PLA preset (Prusament)...how is this accomplished? M600 assumes you're changing the color of a filament with the same diameter and flow properties (which is a big assumption).
In my case, I've tuned the presets since the filament diameter and extrusion multiplier are different, and I want to see these parameters show up in the actual part.
So far, I've had to run the slicer with both filament presets and a color change event (M600), then in an editor, I manually copy and paste the first half of one filament and the second half of the other filament into the same G-code. I was hoping for an in-slicer method.
Thanks.
Postato : 04/04/2023 3:42 pm
RE: Filament preset change with M600 (using 2 or more existing filament presets)
You may find these threads useful.
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
Postato : 04/04/2023 5:54 pm
Royals
(@royals)
Excellent. The multiple extruder trick worked well.
Postato : 04/04/2023 6:24 pm
